March 12, 2003, 09:37 |
Porosity
Hi All, Anyone know how to define a porous medium using CFX 5.5.1
March 12, 2003, 09:44 |
Re: Porosity
not possible. cfx 5.5.1 sux
try using momentum sources, so you could define for example pressure drop at the flow region... |
March 13, 2003, 04:49 |
Re: Porosity
Hi Jan,
here an example how it might look like SUBDOMAIN: porous Coord Frame = Coord 0 SOURCES: MOMENTUM SOURCE: Quadratic Resistance Coefficient = 0.5*density*42300[m^-1] END # MOMENTUM SOURCE END # SOURCES END # SUBDOMAIN where 42300 1/m represents a zeta-value for the pressure drop. Hope this helps, Markus |
April 1, 2003, 19:00 |
Re: Porosity
Hi, Markus!
What's meaning 42300 for zeta-value? and how to use the program you describe in CFX5.1.1? Thanks a lot! |
Problem in setting porosity region for rhoPorousSimpleFoam | run_cfd | OpenFOAM Pre-Processing | 1 | May 31, 2011 09:02 |
Porosity field in Fluent | wojciech | FLUENT | 1 | September 20, 2010 11:19 |
UDF for porosity | Giacomo | FLUENT | 3 | July 23, 2007 09:23 |
porous media with variable porosity | Kevin A. | FLUENT | 3 | December 24, 2006 10:56 |
Media with low porosity | Emmanuel Resch | Siemens | 0 | September 29, 2006 12:44 |
