momentum source
Old   March 17, 2003, 11:37
Default momentum source
sxf
We usually know the Fan flow rate and pressure. How to change it into momentum source. Thanks
-------------------------------------------------------------------- | | INLET | FAN | OUTLET | | -------------------------------------------------------------------- mass flow rate 5kg/s. Fan increase the pressure 100pa. What is the Momentum Source for this case. inlet 0.5m*0.5m. long 5 m, Fan subdomain long 0.3m.
Old   March 20, 2003, 16:38
Default Re: momentum source
Pascale Fonteijn
Trial and error? Then getting the mass flow rate is not that hard. Hope the pressure will match....
Pascale
Old   July 29, 2010, 02:42
nag
arjun
nag is on a distinguished road
hai i am also having the same problem can u just explain me, how to give momentum source for fan plz.........
nag is offline   Reply With Quote
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
