Porosity
Old   March 12, 2003, 09:37
Default Porosity
Jan
Hi All, Anyone know how to define a porous medium using CFX 5.5.1
Old   March 12, 2003, 09:44
Default Re: Porosity
bogesz
not possible. cfx 5.5.1 sux
try using momentum sources, so you could define for example pressure drop at the flow region...
Old   March 13, 2003, 04:49
Markus
Hi Jan,
here an example how it might look like
SUBDOMAIN: porous
Coord Frame = Coord 0
SOURCES:
MOMENTUM SOURCE:
Quadratic Resistance Coefficient = 0.5*density*42300[m^-1]
END # MOMENTUM SOURCE
END # SOURCES
END # SUBDOMAIN
where 42300 1/m represents a zeta-value for the pressure drop.
Hope this helps,
Markus
Old   April 1, 2003, 19:00
hannah liang
Hi, Markus!
What's meaning 42300 for zeta-value? and how to use the program you describe in CFX5.1.1?
Thanks a lot!
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 09:02
Porosity field in Fluent wojciech FLUENT 1 September 20, 2010 11:19
UDF for porosity Giacomo FLUENT 3 July 23, 2007 09:23
porous media with variable porosity Kevin A. FLUENT 3 December 24, 2006 10:56
Media with low porosity Emmanuel Resch Siemens 0 September 29, 2006 12:44
