Way to evaluate results
I have a quick question about evaluating my results of a 4 stage axial compressor. I'm interested in the contours of the first stage. For example, I want to export pictures of the Mach Contour or the Velocity, I can choose between "Mach-Number" and "Mach-Number in Stn Frame" and between Local and global. I thought that I should use the Stationary Frame value, but maybe I'm wrong. Which way is the best/most appropriate way for exporting results for a thesis? Thank you very much :) Daniel |
They both show different things, so the variables are important for different uses.
Yes, that's what I thought is important. So there is no perfect choice ?
