user expression- value from previous time step
Hello all,
I have created a user expression, net energy = inlet energy - outlet energy. and defined this in solver monitor. I need to calculate the accumulated value of net energy over the solver run. I introduced a dummy variable D where D = net energy, so that net energy = (inlet energy - outlet energy)+D; It calculates 2 times the net energy by this expression. I believed the expression will work in step by step in the order defined like in C++ or matlab but it dose'nt work like the way. Any suggestions on how to access the previous timestep of user defined variable? |
Over time? Monitor it?
Do you want to integrate this variable over time? I would suggest to add a monitor point for it. After the run is complete, export the monitor point plot data to another program such as GNU Octave to perform the integration.
https://www.gnu.org/software/octave/...f-One-Variable has details on the numerical integration function that I would use. |
I do not want to integrate it. I want to store an expression in the current time step and need to use in the next time step and it goes on like that.because from timestep number 1 i need to use a expression value which is calculated fron the previous time step. |
The recommended way of doing this is with user fortran. There is a work-around using the TRANS_LOOP variables (do a search of the forum to get more information on it) but it is not supported and definitely use at your own risk.
In your example, are "inlet energy" and "outlet energy" singled valued quantities?
If so, you can benefit from the monitor Expression features which includes a few additional operations in time for the underlying expression. |
accumated addition of an user expression
