CFX/Ansys FSI Error
Old   July 14, 2011, 18:35
Question CFX/Ansys FSI Error
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
Hi all,
I was wondering if anyone had come across this error when running CFX with Ansys Multifield. The model is of an aortic heart valve in 2D.
The problem is that the solution can't get past the first coupled step and the Ansys solver fails with the following error:
One or more elements have become highly distorted. Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere. Try ramping the load up instead of step
applying the load (KBC,1). You may need to improve your mesh to
obtain elements with better aspect ratios. Also consider the behavior
of materials, contact pairs, and/or constraint equations. If this
message appears in the first iteration of first substep, be sure to
run shape checking of elements
I've tried all that is suggested in the error text as well as reducing the time step size to see if the loads were being appliled too quickly. I'm not sure how to go about running shape checking when using coupling as the post processing is done using CFD post and not in Ansys Mechanical.
Any help would be greatly appreciated as this is driving me crazy, no matter what i do nothing seems to change.
Thanks
Andy
Andrew.Coughtrie is offline   Reply With Quote
Old   July 15, 2011, 09:58
stumpy is on a distinguished road
The error means the Mechanical mesh distorted too much. Look at the forces sent from CFX (in the ANSYS.stdout) file and determine if they are reasonable. If not, look at the pressure on the wall in the CFX solution before it fails to figure out why. Since it fails in the first timestep you'll need to create monitor points for the force and displacement on the wall and enable "Monitor Coeff. Loop Convergence".
stumpy is offline   Reply With Quote
Old   July 19, 2011, 16:35
Andrew Coughtrie
Thanks for the suggestions Stumpy they have been helpful in determining what the issue is. The pressure at the Fluid-Solid interface increases at each coupling step of the first time step. The pressure oscillates until it reaches +/-1E+06[Pa]. I've been unable to work out what is causing the solution in CFX to act as it does, I've tried different boundary conditions and altering the solutions control settings but they don't seem to change anything. Any suggestions?
I've attached the CCL file and an image of how the pressure monitor is acting if it helps anyone in determining a course of action I might be able to pursue.
Thanks
Andy
Old   July 21, 2011, 14:57
This shows an unstable interface solution. Search the CFX forum for the thread with the title "FSI and size of time-step". Look for the discussion on applying a source term coefficient to stabilize things.
Old   December 4, 2017, 10:07
Default did you solved that problem?
malekan.cfd is on a distinguished road
Dear Andrew,
I'm doing a FSI simulation and ecountered the same problem as you, have you solved that problem? If so, could you please let me know how?
Thanks,
Malek
malekan.cfd is offline   Reply With Quote
distorted elements, error ansys fsi, fsi, heart valve, multifield
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
