December 7, 2017, 04:44 |
Calculation gets stuck
Jiri
Rep Power: 13 |
I analyze flow in bearing, multiphase flow - oil and air. This analysis is running and suddenly gets stuck, in the middle of an iteration, without any obvious warning or evidence of divergence. It occurs on different computers, also in cluster, so it should be problem of the analysis and not the hardware problem. For different boundary conditions it suddenly diverges, but for other boundary condition it just gets stuck in the middle of an iteration. Is this stucking caused by divergence? |
December 7, 2017, 05:40 |
Rep Power: 143 |
Please attach your output file. That will show where it is getting stuck.
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
Increase in CPU number during the FIRE calculation | amin_u50 | AVL FIRE | 0 | August 6, 2014 08:34 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
