June 10, 2003, 21:06 |
INSUFFICIENT CATALOGUE SIZE
*** INSUFFICIENT CATALOGUE SIZE *** | | | Action required : Increase the file catalogue size. | | | | Current catalogue size: 24980
How to solve this problem Thanks |
June 11, 2003, 09:25 |
Re: INSUFFICIENT CATALOGUE SIZE
Hi Xfshi.
This works in CFX-5.5.1: Go into >tools in the solver manager. Choose: >edit definition file. expand the Flow section in the definition file, highlight the Solver Control section and add the parameter: >Catalogue Size Multiplier into the solver control section. In this way you can multiply your catalogue size by a number of your choise. I hope this helps. Best regards Jesper |
June 11, 2003, 11:16 |
Thanks Jesper. Could you show me the Syntax of real, "character, integer, logical and double precision"
June 11, 2003, 14:16 |
| | | *** INSUFFICIENT CATALOGUE SIZE *** | | | | Action required : Increase the file catalogue size. | | | | If the situation persists please contact the CFX Customer Helpline | | giving the following details:- | | | | Current catalogue size: 39800 | | | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = MGBMIN CDTYPE = INTR ISIZE = 1 CRESLT = FCAT An error has occurred in cfx5solve: The CFX-5 solver exited with return code 1. No results file has been created. |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Error Message: INSUFFICIENT CATALOGUE SIZE | ahlo | CFX | 2 | December 14, 2007 15:59 |
