create screw in CFX built
Old   July 5, 2003, 12:07
Default create screw in CFX built
methee
Hello all,
I have a problem in creating a screw in CFX5.5.1, In order to generate giometric solid as a screw shape, I created a screw surface from many curve and when i have a close surface, then I created a solid by using b-rep. But the program report that there are a gap between a surface and no solid created. Could any body give me some idea how can I fix this problem please.
Thank you very much for all kind answer, Methee.
Old   July 8, 2003, 22:28
Default Re: create screw in CFX built
zdong
try to change the tolerance when you set up the problem...for example change from 0.05 to 0.1..
Good luck
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
Error: create mesh in CFX Ac-Joker CFX 2 June 11, 2009 06:52
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
