ONB and CHF prediction in upward water channel with heated walls
Old   January 11, 2018, 01:48
Red face ONB and CHF prediction in upward water channel with heated walls
ali
ali_kntu is on a distinguished road
hi dears
i have problem in modeling of upward water channel with heated walls. inlet water temperature is 45 C. heat flux is increases until small bubbles appears.
my problem is bubbles make very late, for example when walls temperature reaches to near 180 C initial bubbles are makes, but in text book it is mentioned that by 10C wall supper heating (from saturation ) ONB is occurs.
and second question:
can CFX predict CHF, how could i calculate CHF(DNBR) in CFX.
Thank you
ali_kntu is offline   Reply With Quote
Old   January 12, 2018, 03:15
I know what the acronym CFX means, but I do not know all the other acronyms you used. Please define all your acronyms.
Old   January 13, 2018, 05:57
Default Chf ، dnb
ali
Onb is onset of nucleate boiling ، and it is occurs when wall temperature is about 10C more than saturation temperature
Chf is critical heat flux which film boiling started
Tanx
Old   January 13, 2018, 17:37
Have you done the CFX tutorial examples on nucleate boiling? They are available in the ANSYS Customer webpage. Note there are many factors you will need to adjust to model your configuration. A critical one is parameters defining the nucleation sites on the heated wall surface, but there are many others.
