January 15, 2018, 11:10 |
Drag coefficient CEL expression
cfxtwophaseflow
Rep Power: 8 |
I want to set a new drag coefficient for a bubbly flow. I know how to do it by CEL expressions but I want to use it in multiple cases, not just one simulation. I don't want to rewrite the CEL expression for every simulation. Is it possible to write the CEL expressions in an external file and to call them for every simulation? Have you any suggestions?? |
January 15, 2018, 14:24 |
Rep Power: 32 |
In CFX-Pre, using the existing case with the expressions you want to reuse
go to File->Export->CCL select the section of the command you are interested in, say Expressions, named the export file as you please and save. Later, in your new case, use File->Import->CCL, select the exported file, and you should have the desired expressions added to your new setup. Hope the above helps, |
January 16, 2018, 09:54 |
#3 | |
cfxtwophaseflow
Rep Power: 8 |
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 11:03 |
problem with saving drag coefficient | colopolo | FLUENT | 5 | April 12, 2013 10:59 |
Post Processing Drag Coefficient | squanto773 | OpenFOAM Post-Processing | 1 | March 7, 2012 09:43 |
Plot drag coefficient against Y(distance) | edwin | FLUENT | 0 | February 4, 2008 09:41 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
