CEL for Void Fraction gradient
Old   January 15, 2018, 14:25
Default CEL for Void Fraction gradient
cfxtwophaseflow
sarrazs is on a distinguished road
Hi
I want to calculate the components of the gradient(void fraction) with CEL expression.
I defined a variable eps = air.vf
then I defined var1 = eps.Gradient X
var2 = eps.Gradient Y
var3 = eps.Gradient Z
I get this error :
Bad expression value 'Cvm2' detected in parameter 'Virtual Mass Coefficient' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/FLUID PAIR:air | water/MOMENTUM TRANSFER/VIRTUAL MASS FORCE'.
CEL error:
The following unrecognised name was referenced: eps.Gradient X, eps.Gradient Y, eps.Gradient Z.
I don't know why I can't use the gradient operator with eps and is there another way to do it?
sarrazs is offline   Reply With Quote
Old   January 15, 2018, 14:31
cfxtwophaseflow
I just solved this problem. I used air.vf.Gradient X instead of eps.Gradient X
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Zero Gradient for Volume fraction at inlet Kushagra CFX 1 January 1, 2014 06:58
The gradient of void fraction in UDF summer FLUENT 2 May 20, 2011 04:34
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 11:46
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
