inlet setting
Old   July 16, 2003, 04:26
Default inlet setting
Rebecca
Hi all,
I like to ask a simple question about the setting of inlet that how to set the velocity in the unit [rpm]? Should I set a equation in CEL for this? or change the frame to Rotating Frames of Reference?
Thank you for your response!
Rebecca
Old   July 19, 2003, 16:11
Default Re: inlet setting
Robin
Rebecca,
[rpm] is not a unit of velocity. What is it you are trying to do?
Robin
Old   July 21, 2003, 14:03
Rebecca
Robin,
I like to simulate the impeller with different rotational velocities. Would you please suggest me? Thanks for your help.
Rebecca
Old   July 21, 2003, 14:45
Robin
Hi Rebecca,
If the domain is rotating, you should specify it in the domains form. When you create your inlet boundary condition, there is an option to specify it relative to the stationary domain. Doing so, the solver will automatically add the rotating component to your inlet condition (essentially adding v_theta = omega*r).
Regards, Robin
[TGrid] Inlet passage in turbogrid. soldimix15 ANSYS Meshing & Geometry 0 September 5, 2010 11:34
Pulsating flow with non-reflective inlet boundary cc1000 CFX 6 April 27, 2009 08:10
boundary condition velocity inlet dont have gauge pressure setting value? coolyihao FLOW-3D 0 March 17, 2009 10:17
Problems with Inlet species San24 Siemens 1 May 7, 2008 06:29
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 10:22
