January 18, 2018, 06:45 |
CFX halts in parallel, not serial
Rep Power: 17 |
I have been using CFX for many years, but just came across some odd behaviour, where a new installation of version 18.2 does only work in serial, not in parallel. There is no error message when trying a parallel run, only the output file saying "SOLVER" after partitioning is finished - and it does not proceed any further. I can see the "cfxsolve" occurences (though showing as 32 bit) in the process tree. I have to kill all of these manually to close Workbench and start over. The computer is running Windows 10. |
January 18, 2018, 12:27 |
Erik
Rep Power: 23 |
Do you have a static IP address? Is this a laptop? Are Ethernet connections turned off? Do you have internet connection?
January 18, 2018, 19:01 |
Rep Power: 11 |
Which MPI are you using? Did you update the MPI software from previous version? Did you try the other MPI (platform vs Intel)?
Parallel vs Serial Run-Solver manager | rohit_turbo | CFX | 5 | March 4, 2016 08:34 |
Remote cluster parallel solve without master, Ansys CFX 14.5 | aaguirre | CFX | 4 | January 27, 2015 09:15 |
Parallel Problem of CFX 14.5.7 on a Intel Xeon 2690V2 computer with Win7 x64 OS | BruceWen | CFX | 14 | September 16, 2014 19:25 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 19:05 |
Serial vs parallel different results | luca | OpenFOAM Bugs | 2 | December 3, 2008 10:12 |
