Wall and Boundary Scale (SST)
Old   February 7, 2018, 04:50
Default Wall and Boundary Scale (SST)
Patrick
b4kerman is on a distinguished road
I am running a simulation using the SST model and the "Wall and Boundary Scale" in the Solver Manager is decreasing to e-5 in the first iterations and is constant after that. I am used to no value after the first iterations instead of a constant value. Is this ok or is there some problem regarding my mesh?
b4kerman is offline   Reply With Quote
Old   February 7, 2018, 05:08
The solver does a diffusion based solution using the solver to get the wall scale variable - which is the distance from the nearest wall. Usually this equation converges quickly to a tight tolerance and then stops, while the rest of the simulation progresses with the other equations (which are much harder to solve).
So this is normal behaviour.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 7, 2018, 05:13
Patrick
Perfect, thanks!
Old   October 30, 2018, 06:51
elia_l is on a distinguished road
Sorry ghorrocks, I havent clear what this indicator means. you just said "the distance from the nearest wall"... the distance of what? Could you kindly explain more in depth the concept?
Really thanks in advance.
elia_l is offline   Reply With Quote
Old   October 30, 2018, 16:50
The variable is the distance to the nearest wall of the node. That's all, very simple.
Old   October 30, 2018, 23:30
thanks a lot ghorrocks! i supose it is expressed using the adimensional form (y+), isn't it? and the value shown by the chart each iteration is the RMS or MAX value (depending on selection) all over the domain walls, is it right?
thanks again in advance
Old   October 31, 2018, 07:59
Opaque will become famous soon enough
The default plot in the solver manager for Wallscale is the RMS residual as the solution is converging. Once the solution has converged to the specified criteria, the equation is no longer solved.
In some releases shows as a constant residual from there on, in other releases the line is no longer plotted and it stops at the iteration when convergence was achieved.
The wall distance is computed from the wallscale equation solution, see documentation for details.
Opaque is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
