Supersonic flow
4 Attachment(s)
I am doing CFD of turbomachine operating in supersonic flow in absolute frame. I am using CFx 17.1
Solver : k-w I have set reference pressure as 0 Bar Specified inlet conditions total temperature in stationary frame: 300 K total Pressure in stationary frame : 101325 pa And inlet velocity : 500m/s Outlet : I left it as supersonic (Is it good approach?) My fluid domain is small so I kept outlet as supersonic. Length of inlet and outlet domain is approx 320 mm. But I can see that velocity in result file is unbelievable and at inlet is of order of 3000 m/s !!! I have uploaded velocity contours, mach number contours, monitor of velocity during run at inlet (this velocity is area average over inlet) and residuals. Please....Can somebody help me What I am doing wrong here? Thank you so much. Attachment 61297 Attachment 61298 Attachment 61299 Attachment 61300 |
Step 1: Using Bernouilli-equation, calculate the static pressure on the inlet based on the conditions you provided. Then you'll see what is going wrong.
Step 2: Change it into something realistic. |
