How to monitor an expression on a "ghost" location?
Old   February 18, 2018, 19:51
Default How to monitor an expression on a "ghost" location?
Guille1811 is on a distinguished road
Im running a transient and i need to monitor the max temperature value on the imaginary finite line defined by the points (0,1,0) and (0,1,150). I donīt know how to do this since the line is not a physical entity and doesnīt belong to any location compatible with cfxpre monitor setup.
Any help?
Guille1811 is offline   Reply With Quote
Old   February 19, 2018, 02:47
This is easy in post processing, but I assume you want to do it in the solver. Can you put a series of monitor points along the line and export it and get the maximum from there? It is a bit of a hack but easy to implement.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 19, 2018, 04:21
Gert-Jan
Gert-Jan will become famous soon enough
You can create a lot of monitoring points on this line and monitor the temperature on each point. A monitorplot in the solver manager will show you which monitor point has the highest temperature.
Alternatively you can create a plane (thin strip) in your geometry and mesh it as an interface. Then this interface appears as mesh locator in CFX-Pre which can be used in monitoring the maximum temperature.
Gert-Jan is offline   Reply With Quote
Old   February 19, 2018, 11:25
I was rhinking to do somthing like that, but i need it to make it work in a bit more elegant way. Im thinking of th following:
Create a temperature monitor every 5 mts (so it would be 30 monitors) and also create a variable/expression that takes the value of the maximum value of all the monitors. In other words, something like: maxtemp= maxVal(all the monitors), so the value of the expression would be the max temp every timestep and i then i can simply monitor that expression and problem solved.
Can this be done? Particularly setting a CEL for pcking the max value in a set of variables/expressions...
Old   February 19, 2018, 11:33
or alternatively the max temp of the PREVIOUS timestep, if that is any easier to implement
Old   February 19, 2018, 11:53
Gert-Jan
Monitor points are not mesh locators. So you cannot use them in expressions like maxVal
Old   February 19, 2018, 11:59
Yes indeed, i was not suggesting to use that specific function as the solution, it was just to make my intention clear. Sorry if i expressed myself badly.
Old   February 19, 2018, 12:03
Gert-Jan
Your intention is completely clear.
It is just that it is not possible to use Monitoring points in any equation or CEL expression since these points are not mesh locators. So, there is no solution, other than what I wrote in my previous reply.
Old   February 19, 2018, 12:18
Thanks for the response.
What if a create a probe for every temperature monitor? Something like:
Monitor 10 mts: temperature at (0,1,10)
temp at 10 mts: expression defined as probe(Temperature)@Monitor 10 mts
Then i could find the max value among all those expressions, can this be done?
Despite, is there a CEL command to find the max value among a set of expressions (or a set of anything is thats the case) ?
Old   February 19, 2018, 12:54
Gert-Jan
In CFX-Pre, you should go to Definition window of the expression section, and press your right mouse button, you will see that there are numerous options. By selecting Funtions>CEL you will see that there is max-function, and many more.
So, yes you can use a function like max(T1,T2) which will give you the maximum of T1 and T2. And T1 and T2 can be something like T1=maxVal(T)@outlet and T2=maxVal(T)@Wall, since Wall and outlet are meshlocators.
But T1 nor T2 can be related to a monitoring Point because they aren't meshlocators.
Old   February 19, 2018, 17:42
Thanks for the tip but sadly that function only accepts 2 expressions as input and i would need to obtain the max between like 30 expressions...
Old   February 19, 2018, 17:50
Gert-Jan
So, you have to use the max-function 30 times to determine the maximum. This is still doable. Go to Expressions, and use your right mouse button to edit the expressions in Command Editor, so you can copy paste the expressions and modify them as in a text editor.
I consider this as a bit silly and think it is easier to create a mesh on a small strip (as an interface) along the line of interest and monitor the maximum on this strip: maxVal(Temperature)@interface
Old   February 19, 2018, 21:15
I guess i will do the first option. Thanks for the help.
One more question: should the total run time increase a lot because of all the 30+ expressions defined?
Old   February 20, 2018, 06:32
No, 30 simple expressions should not affect run time. But don't take my word for it, do a run with and without the expressions and see for yourself.
Outlet boundary condition in interFoam Andrea_85 OpenFOAM Running, Solving & CFD 51 July 20, 2017 14:31
Set "location" in CEL expression to local plotting location Jonathan CFX 0 July 1, 2015 08:21
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
