February 22, 2018, 11:43 |
Cfx pre warning/error
Rep Power: 14 |
I am doing a Wind turbine simulation and hence I have an interface and I am keeping the rotor stator interface pitch angle as none that means am not giving any 360 360 degree otpion there and its frozen rotor
And during writing the solver file am getting this error or warning. Is it ok or is there something wrong ? Should I consider this or should I avoid this ? The image is attached !! Thanks in advance |
February 22, 2018, 14:25 |
M
Rep Power: 12 |
Not completely sure, but this warning is also issued when using expert parameters or beta features. It does not necessarily mean something is wrong with the setup.If you think your setup is ok, you can just ignore it. If your results are strange though, you should have a deeper look into it.
February 22, 2018, 16:15 |
Gert-Jan
Rep Power: 27 |
This pup-up can mean a lot, it can also mean nothing.
You should pay attention to the white panel on the right hand bottom side of your Pre-session. There the real error messages are given if there is one. It could also be only a warning, But we cannot see this since your print screen does not show this white panel......... |
Command editor is not visible in CFX Pre 17.2 Windows 10 | hmdl | CFX | 3 | December 23, 2020 14:17 |
Green Cones appearing in CFX Pre | lionelopittmanjr | CFX | 1 | February 25, 2017 05:46 |
CEL expression in CFX pre | Jane92 | Main CFD Forum | 1 | June 3, 2016 02:48 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
