How to define a internal boundary.
Old   September 22, 2003, 09:26
Default How to define a internal boundary.
windhair
I want to define a internal boundary in a block, where a constant value is fixed on this surface, is it possible in CFX 4.4 using user subroutine? Which type of patch should I define there?
Thanks
Old   September 28, 2003, 23:04
Default Re: How to define a internal boundary.
youngan
I copy the follow from the cfx document in page3-570. I hope it is helpful. Btw: Are you using the same ID in aoxue Forum ?
It is sometimes the case that you wish to prescribe the velocity at some internal point of the flow domain rather than giving a source of momentum. In this situation there are two ways of proceeding. First, it is possible to use an internal inlet and outlet, but they must be situated on a solid region. The second method, which should only be used with great care, uses source terms in the momentum equations by setting: SP = -c SU = c*value AM = 0 for all six facial components
Old   September 30, 2003, 11:15
windhair1
Thanks, that is me.
Thanks for you information, but what I want to define there is not velocity. In short, it is a additional user scalar, and I need to set a boundary condition for such scalar inside the flow domain, and sovle a Poisson equation for such it, and this will have no direct influence to other variables.
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
How to define the velocity_inlet boundary condition with existed data for a face? Byron FLUENT 4 September 4, 2010 03:47
setting boundary conditions on internal edges Renate Stump FLUENT 4 November 7, 2008 10:55
boundary conditions for internal faces Tom Pendrey FLUENT 1 March 5, 2007 18:25
Internal boundary condition Fred CFX 0 December 28, 2004 13:57
