Subsonic and Transonic Flow
Hello there,
I am simulating a 4-stage axial compressor with subsonic flow. When I evaluated the mach-number at the inlet of the first rotor row, the Mach-number near the Shroud reached 0.85. For me this is a little but curious since I defined the flow with subsonic. Is it normal, that the Flow exceeds 0.8 for transonic flow conditions? Thank you very much! |
yes very much normal
Thanks for the answer :)
But is there any explanation for this ? |
isnt is the velocity triangle. at tip the blade speed is higher, so the mach number
you have to check it is relative mach number or mach number.
I only can choose Mach Number and Mach Number in Stn Frame.
And for the Rotor I've chosen the regular Mach Number. |
