Y+ values in ANSYS/FLOTRAN
Old   October 15, 2003, 16:30
Default Y+ values in ANSYS/FLOTRAN
David Creech
I had a chance to speak to one of the FLOTRAN developers on the issue of the recommendation of y+ values in the FLOTRAN manual. The manual states that y+ values up to 5000 can be used in a favorable pressure gradient. Some doubt was expressed in this forum
The recommendation comes directly from White's Viscous Fluid Flow book, section 6-4.1. Figure 6-9 shows the validity of wall laws by plotting experimental data for several flow types (separating, adverse, favorable). For strong favorable flows, the wall law is valid up to y+ vlaues of 5000.
The important point here is that you must evaluate your grid based on flow type. A general guideline that y+ should be less than 350 is not good for all situations.
This message is in response to an old post in this forum
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
Y+ values in ANSYS/FLOTRAN Franklin Palheiros CFX 6 June 26, 2003 09:06
