Injection Spray into Air with Opening Pressure of 30bar |
March 27, 2018, 16:36 |
Rep Power: 8 |
Hello guys
I'm new here because I need your advice: Currently, I'm simulating a water spray, which is coming out of a 0.75mm nozzle diameter. The spray injects in a surrounding of air with 30bars opening pressure. Following some details: Analysis Type: Steady StateFluid Definitions: Air as Ideal Gas, Water, both stationary, non Buoyant, Continuous FluidTurbulence: SSTInlet: Inhomogeneous Velocity Profile (CSV-File), average 300 m/sOpening: 30barsWall: Free Slip WallMy problem now is, that I can't find a solution which lead my RMS to convergence. I tried physical timescale with 1E-8, but even there, after 500 iteration, the following problem appears: Overflow I'm using a student licence, which doesn't allow me to exceed the number of nodes of 500'000. The "mesh quality" may cause some problems or the inhomogeneous velocity profile. But actually, a simulation with opening pressure of 1bar did end successfully. So, what do you think may solve my problem? Do you have any suggestions or good advice? If you need more information, please let me know! Thank you for help and replies! |
March 27, 2018, 19:02 |
Rep Power: 143 |
Which multiphase model are you using?
Why are you doing the simulation? What are you intending to get out of the results?
March 28, 2018, 06:41 |
Gert-Jan
Rep Power: 27 |
Spray, 30 bar, 300 m/s. This is a very complicated case with difficult physics.
Don't try to go for the top from scratch. Start simple: atmospheric & 10 m/s and then gradually increase complexity and see where it fails. |
April 5, 2018, 05:25 |
Rep Power: 8 |
I'm using the Standard Free Surface Model with Turbulence Shear Stress Transport .
I'm intending to simulate the spray breakup and its distraction after the nozzle outlet. However, I reached a full calculation without any error messages. Unfortunately, it didn't come to nice convergence (see picture). At the iteration of around 890 some of the residuals seem to rise / diverge after they fall below abort criterion of 1E-5. My question is now, why? I guess it could be: due to the physical timescale, which need to be smaller[/LIST]or the mesh is too imprecise / not too fine for the job. But, what do you think? Does anyone have some experience with that? If you have some questions, please don't hesitate to ask me. I thank for every answer! |
April 5, 2018, 05:53 |
Gert-Jan
Rep Power: 27 |
- Why do you use free surface model. This is for flat surfaces of e.g. water to study waves.........
- is your plan to predict the water droplet size at the outlet? If so, did you include surface tension? - Regarding the residuals. Can yo ushare the mass and momentum imbalances? |
April 5, 2018, 06:35 |
#6 | |
Rep Power: 8 |
- No, not the droplet size, just the spray in general. - I added it in the attachement Thank you very much for your help Gert-Jan! |
April 5, 2018, 06:42 |
Rep Power: 143 |
Is this is what you had in mind? https://www.youtube.com/watch?v=O0aynlUkRBQ
Modelling high pressure spray breakup using a free surface model means you are modelling some seriously difficult physics in minute detail. This is not something for the CFD beginner - you will require careful model development, a supercomputer and a lot of computer time. I have some experience in modelling similar flows and I can assure you it is extremely challenging. Can I ask why are you modelling this, and what do you intend to learn by doing the simulation?
April 5, 2018, 06:49 |
#8 | |
Rep Power: 8 |
Well, this looks really nice, but isn't what I intend to do. It doesn't need to be a animation nor a transient simulation. In my case, everything is stationary. Is there another way to simulate my case, like with another model? I'm currently doing my bachelor degree in Mechanical Engineering and specialize in Thermo- and Fluid-Engineering. Thanks for your answers and help so far! |
April 5, 2018, 06:53 |
Rep Power: 143 |
High pressure spray breakup is an inherently 3D transient flow. You cannot model it steady state as you appear to have done so far with a free surface modelling approach.
Can I ask why are you modelling this, and what do you intend to learn by doing the simulation? The reason I ask this is because there are many other ways of modelling sprays which are FAR easier. Eularian and Lagrangian droplet models are available which are much more reasonable simulations but they require simplifications and assumptions to be made. That is why you need to know what you are trying to learn from the simulation before you can choose an appropriate model.
April 5, 2018, 07:05 |
Rep Power: 8 |
I'm currently doing my bachelor degree and investigate in my thesis (diploma of the last semester) liquid sprays. I want to know, how sprays change, when some properties (temperature, pressure, viscosity, ... ) will be modified.
The thing is, that the simulation of a homogeneous inlet profile (everywhere the same normal speed of 300 m/s) works properly and with less iteration. When I activate the inhomogeneous inlet velocity profile, everything get more complex. So, and I solved the spray (see attachment above) and I ask, why the residuals diverge after ~890 Iteration. Is the model incorrect? Wrong mesh size? Any suggestions? |
April 5, 2018, 07:39 |
#11 | |
Rep Power: 143 |
There will be literature papers around which have already done this sort of thing, so you just need to dig up the papers and use their results to get the spray properties. There is no need for you to model anything. Also: CFX has a spray breakup model suitable for this pressure range for lagrangian particle tracking. This model was built for diesel fuel injectors but with a bit of work it should work for your flows. Have you considered using this model rather than a free surface model? It will be MUCH easier to get useful results from this model compared to your current approach.
April 5, 2018, 08:18 |
#12 |
Gert-Jan
Rep Power: 27 |
I fully agree with Glenn. Nevertheless,
- if you want to stick to your plan, don't start with 300 m/s and 30 bar. You can't do what e.g. Bosch Gmbh in germany is trying (!) with a large R&D team and huge cluster. Start with something easier. A bit more down to earth, please. - if you want to do something like in the youtube movie, you should start doing VOF kind of stuff for which I would recommend fluent or star-ccm+ (or even star-cd). Not CFX. Good luck, Gert-Jan |
April 5, 2018, 10:42 |
#13 |
Rep Power: 8 |
Thank you for your help and recommendations.
However, does anyone suggest what it means when the residuals are raising after ~890 Iteration? |
April 5, 2018, 10:59 |
#14 |
Gert-Jan
Rep Power: 27 |
Impossible to say since your mass imbalance is far from zero.
I think the velocity field is still developing. You should imagine a velocity and pressure field that is progressing from inlet to outlet while iterating from iteration 0. Just like opening a valve. So to me it looks like the velocity field has not been developed up until your outlet = my first guess. Of maybe your outlet is completely blocked by artificial walls. Could be anything. Impossible to say as long as your imbalance is way off. So: create a plot where you monitor the imbalances of mass & momentum. These should all go to within 5%. At least. Only then look to residuals. Otherwise these are completely meaningless. Now look at the velocity field of your calculation and see if it makes sense. If not, start from scratch and as simple as possible. Don't try to hit the roof in one go!: 1) Calculation 1: 1 m/s air at inlet. See if you can get this right completely. 2) Restart calculation 1 with new settings: 10 m/s air at inlet. See if you can get this right completely. 3) Restart calculation 2 with new settings: 10 m/s air at inlet and 10% 10 water. See if you can get this right completely. And then progress existing calculations with increasing complexity. Higher velocities, inhomogeneous models, Total energy, etc. And ask your superviser to take a closer look. |
April 5, 2018, 18:37 |
#15 |
Rep Power: 143 |
Your problems are more fundamental than rising residuals after 890 iterations. For instance you are modelling an inherently transient flow with a steady state model. It is never going to work as you currently have it set up.
To get straight to the point: You appear to be a beginner at CFD with very limited resources (student license, 500k nodes) attempting a simulation which is a big task for an experienced CFD person with access to a supercomputer. To put it bluntly, you are not going to successfully complete this simulation. That is why I asked the question "why are you doing this?". If the answer is because my professor told me to - then your professor set an impossible task and you need to get your professor to be realistic. If the answer is because I thought it would be interesting to simulate it - then you should change it to a more reasonable simulation, for instance reducing the spray pressure/speed as Gert-Jan suggests would be a good approach. If the answer is because it is part of a machine I am designing which uses this device to spray fluid - then you should look at either the literature for experimental/empirical work on high pressure sprays and estimate the spray performance from there, or use models like the lagrangian spray model in CFD to model the spray process.
April 16, 2018, 04:26 |
#16 |
Rep Power: 8 |
Thank you everybody for the inputs and answers.
I've just wanted to inform you, that the calculation and simulation finally came to an end and the result is satisfying. There were ~300 Iteration needed and finished after 30min. Thanks to some changes in heat transfer, turbulence model and fluid model the wished solution came out. I'm now very happy that I reached the end of this task and can move forward in my bachelor thesis. With this words I want to finish this thread. If someone has some more questions to my solution, please feel free to contact me via PM. Thank you and kind regards Spray_Ansys |
ansys, cfx, convergance, residual, spray |
Simulation of ball-valve opening w.r.t to varying inlet pressure | wasim_03 | Main CFD Forum | 1 | January 6, 2018 12:40 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
spray injection | mmacrb | FLUENT | 0 | January 10, 2007 04:57 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
