sliding mesh problem
hi,all~~
I'm runing a sliding mesh case, but I encounter a problem. On the interface between moving part and stationary part, the distribution of the temperature does not look like continuous. Is there any good way to improve it? Thanks! Devin |
Re: sliding mesh problem
Hi Devin,
Which code are you using? Are you sure your grid is fine enough? Are you sure your simulation has converged? Glenn |
