symmetry-axis problem
Old   January 27, 2004, 02:53
Default symmetry-axis problem
hx
Hello, every one, I am using CFX 4.4 to simulating a reactor. How I set the symmetry-axis. I am in urgency need your help.
thank in advance,
hx
Old   January 27, 2004, 20:32
Default Re: symmetry-axis problem
Jeff
Are you using slab=wedge?
If so: 1) Axis MUST be the X axis 2) Radial direction must be in Y 3) Axis MUST be at low Y (pref. Y=0) 4) Set the low Y face as a symmetry plane.
Hope this helps, Jeff
Old   January 27, 2004, 22:47
hx
hello, Jeff,
Firstly, thank you for your help! The reactor I am analysing is a reactor similar to CSTR. I do not use slab=wedge. I set the axis the X axis. But the symmetry-axis is a 2D patch.So I set the cylindrical surface around axis the symmetry-axis. Is that right?
Kind regards, Hx
*.msh conversion + axissymetric problem bruxellois4 OpenFOAM 18 March 5, 2020 15:48
2D Modelling of Horizontal Axis Wind Turbine Richeom Main CFD Forum 1 April 7, 2014 17:43
[snappyHexMesh] Layer addition problem near symmetry planes bigbang OpenFOAM Meshing & Mesh Conversion 6 December 8, 2011 06:35
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Help! I want to break the symmetry of my problem David FLUENT 3 February 4, 2005 08:35
