January 23, 2004, 12:15 |
Frozen Rotor Interface Problems
Hello there!
My problem is that a frozen rotor interface doesn`t work in CFX5.6solver since the theta extent is too small. The out file gives three possible reasons for the failure. I went through my topology quite some time and there is none of the latter two (zero radius, surface normal and parallel). I don`t know exactly what is meant by `surface more than 360 degree of revolution` but the geometry only has 120°. I guess I can exclude this cause. Does anyone have experience with a related problem or knows another reason for the interface to fail? What exactly is a too small theta extent? Thanks a lot for the answers! Joe |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Frozen Rotor Model CFX | windsim | CFX | 13 | January 5, 2012 13:25 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Frozen Rotor and Wake of a Wind Turbine | Peter | CFX | 0 | June 26, 2006 15:12 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
