January 20, 2004, 16:42 |
export CFX results to Tecplot
Does anyone konw how to export the three-dimensional simulation results from CFX to Tecplot? It worked for 2D cases where I can export everything on a plane to Tecplot, but I don't know how to do it in 3D. |
January 21, 2004, 01:32 |
Re: export CFX results to Tecplot
Hi
Just export the results from CFX in cgns format. You will be able to load this format in Tecplot v9 and above. Regards Jens |
January 21, 2004, 02:47 |
It is possible to export cgns format from CFX 4? How? Thanks
January 21, 2004, 10:00 |
Jens,
Got it! Thank you so much and have a nice day. |
January 21, 2004, 17:10 |
Hi windhair,
CFX-Post works with CFX4 dump files as well. I think CFX-Post is the current post-processor for CFX4, so if you don't have it you should try to get it. What post-processor are you using? Glenn |
January 21, 2004, 18:00 |
CFX Analysis, seems there are such option in cfxanalysis.
January 27, 2004, 02:55 |
Hi,when I export result file from CFX 5.6 to CGNS,in Tecplot 10 I get only one zone without pervious BC regions and I can't to separate them.Does anyone know where the problem is?Thanks in advance. Zbynek
CFX vs. Fluent Results | n.sharifi | CFX | 8 | November 3, 2010 16:40 |
how to export cfx result to CGNS format | littlelz | CFX | 3 | April 29, 2010 08:15 |
how to export "wall heat flux" to tecplot? | victor | CFX | 3 | November 27, 2008 09:45 |
Import results to CFX post | MatjazR | CFX | 1 | October 17, 2005 09:07 |
CFX post to Tecplot | nandu | CFX | 2 | December 4, 2002 08:27 |
