February 18, 2004, 02:59 |
Restriction on filename?
Is there any restriction on the filename and folder name defined in CFX? I have the file, named "10_10_0p2_1.def", in the folder, named "roof_height". I got the error message that I do not understand in Solver. Thank you very much.
Atit |
February 18, 2004, 03:16 |
Re: Restriction on filename?
I got the error message say something about filename checking in Build with the file named "roofExpand".
February 18, 2004, 04:04 |
I am aware of spaces. You cannot use these in directories and file names. Your file name looks correct to me.
Pascale |
February 18, 2004, 10:03 |
It may be because your def file name begins with a number instead of a letter - I know there are restrictions in CCL on this.
Johnson |
February 26, 2004, 15:14 |
I think there are many, many, MANY cryptic restrictions on all sorts of text fields. I avoid using any special characters besides - (dash) and so far that seems to work.
I think there is / was a restriction on total absolute path length too. |
March 3, 2004, 01:39 |
The problem is with CFX-5 CEL expressions that can contain references to named locations (eg: boundaries subdomains etc.)
So, don't use a dash in any material, boundary, domain name etc... this wont work because it can get misinterpreted as a CEL expression. Neale |
Motorcycle CFD | champion | STAR-CCM+ | 7 | November 7, 2017 10:00 |
convert fileName to double | braennstroem | OpenFOAM Programming & Development | 6 | February 21, 2011 07:59 |
restriction and prolongation operators | rookie | Main CFD Forum | 0 | June 8, 2006 02:28 |
smoothing iterations before restriction | CFD Student | Main CFD Forum | 1 | May 20, 2006 00:06 |
Time Step Restriction | Valdemir | Main CFD Forum | 2 | May 6, 2003 04:55 |
