How to modify the source to make the existed phase disappear
1 Attachment(s)
As shown in the attached figure, does anyone know how to make the injected gas phase disappear, when the injected gas floats out water and meets the top air, or injected gas meets the top gas when the volume fraction of air reach to 1. Thanks for your advices.
Search for "Degassing" boundary condition in the documentation
2.5.1.9. Degassing Condition (Multiphase only) Degassing boundary conditions are used to model a free surface from which dispersed bubbles are permitted to escape, but the liquid phase is not. They are useful for modeling flow in bubble columns. |
How are you modelling this?
If you are modelling it using Eularian bubble model you use a degassing boundary as Opaque stated. If you are using a Lagrangian particle tracking model you could just make the top surface a wall with coefficient of restitution =0. Then the bubbles will hit the wall and be stopped. If you are using a free surface model then you will need to explicitly model somewhere for the air to go, so an opening boundary is a common choice. |
Can I ask how were we meant to guess what you were doing based on your first post? Why didn't you post this information right from the start?
Anyway, to answer your question: If you are using Lagrangian particle tracking you will need to define a track termination criteria for when it reaches the surface. I suspect this could be looking at the volume fraction and if it is lots of air or bubbles over a defined volume fraction you terminate the track. But then, as you say, you will need to use a source term to generate as much air as you terminate in the particle track. |
