inlet distortion simulation use the TBR_FT method
Like Tree1Likes
  • 1 Post By TurBoris
Old   May 18, 2018, 22:10
Default inlet distortion simulation use the TBR_FT method
cliff
view is on a distinguished road
hello everone
I use CFX TBR-FT method to solve a Fan inlet distortion question,it contains a 360° stationary domain,and two rotating passage. The distortion use a 180° subdomain momentum source loss model to simulate a 180° total pressure distortion. But in the result, at the rotor stator face the distortion doesnot transmit to rotor domain,I donot know where is wrong, I wish your help, thanks!
view is offline   Reply With Quote
Old   January 17, 2021, 04:55
TurBoris's Avatar
Bora
TurBoris is on a distinguished road
In this type of model, the distortion profile should be rotating, otherwise the stationary parts will be always exposed same part of the distortion profile. First you need to run this case as full wheel steady with frozen rotor interfaces. Than extract the distortion profile at fan inlet. Second, in TBR simulation, initialize this profile and create a rotating coordinate frame same as rotor speed. Assign the inlet with this distortion profile and rotating coordiante frame.
aero_head likes this.
TurBoris is offline   Reply With Quote
Pleated Filter Simulation method touyet FLUENT 0 April 30, 2018 01:21
Feeding Inlet Conditions to a simulation AS_Aero CFX 7 May 13, 2017 07:34
Pressure input for Velocity Inlet in middle of 2D transient Simulation Shekhaai FLUENT 1 August 30, 2016 23:43
inlet condition in preconditioning method ricklee Main CFD Forum 0 January 30, 2006 14:35
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 03:34
