March 10, 2004, 08:00 |
Timestep in transient flow
Hi all, How can I compute the timestep in transient flow?? thanx
March 10, 2004, 16:47 |
Re: Timestep in transient flow
Hi Zaher,
Do a timestep independance study. Choose a sensible sounding starting point, do a simulation, get an answer. Rerun with half the timestep. If the answer is the same you should be timestep independant. If different then rerun with the timestep halved again. Keep repeating and halving the timestep until you get the same answer. Glenn |
March 13, 2004, 02:48 |
Thanx
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 19:43 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
Poor Convergence for Transient Subsonic Diffuser sims with flow separation | TWaung | CFX | 1 | April 16, 2009 08:25 |
periodic and transient flow | Somchai | FLUENT | 2 | March 26, 2007 22:37 |
PhD in turbulence | Hans | Main CFD Forum | 14 | October 8, 2001 03:03 |
