cylindrical co-ordinates
Old   March 27, 2004, 16:13
Default cylindrical co-ordinates
aj
Hows it going.
I'm a Final Year Mechanical Engineering student and my project involves CFX design and analysis.
I've created the necessary geometry in Build and the inlet i require is as follows: an inner and outer radius have a surface defined between them. I want this surface to be the inlet-the inlet is like a ring as such. I know the air velocity travelling perpendicular to the plane of the inlet, but i need it deflected at 45 degrees in all directions after it passes througn the inlet. The problem i'm encountering is how to use the cylindrical co-ordinates in CFX-Pre. The z, theta and r components have to be entered in m s^-1 in CFX 5.5, and i don't know how to specify these, knowing just the velocity perpendicular to the inlet.
Any help at all would be great.
Finite Volume Method For Cylindrical Coordinates falopsy Main CFD Forum 45 August 14, 2023 21:14
Area of Cylindrical Cutting Planes chegdan OpenFOAM 1 October 6, 2011 14:43
Cylindrical coordinates ? T.D. OpenFOAM Running, Solving & CFD 17 September 26, 2010 15:37
cylindrical coordinate-Gambit noussa FLUENT 0 June 8, 2010 08:08
Cording Ground.for in Cylindrical coordinate J.H. Lee. Phoenics 2 March 28, 2003 04:28
