[Sponsors] | |||||
bad results of steam jet condensation into subcooled water |
pie chen
Rep Power: 10 ![]() |
The settings are as follows:
The phenomenon is steam jet condensation into a water tank。 Particle model was applied in the model, steam as dispersed phase and water as continuous fluid. As to fluid models, both phases was set by thermal energy. The boundary condition: the steam inlet condition was mass flow rate condition. The outlet boundary is set as opening condition,the entrainment pressure is 0 Pa. Solver control-advection scheme-high resoluton. Physical timescale is 1e-06s. I can get the following results(void fraction at a axial cross section): ![]() ![]() The void fraction profile by other researchers is: ![]() Anyone can tell me why I can't get the results as other's? Thank you so much if you can read my thread. |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Read the FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
And are you sure you have run your model for enough physical time? And that it is converged? Also - you show one image going up, one down and the work by other researchers goes across. Does the direction (relative to gravity, I presume) make any difference?
pie chen
Thanks for your kind reply. I will check it as your advice.
| Tags |
| steam jet condensation |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| coaxial jet flow into an open water tank | sreesha | FLUENT | 0 | January 26, 2017 15:29 |
| Steam condensation | narendra.gadwal | FLUENT | 1 | April 26, 2012 08:33 |
| Help!simulation of free water jet | Annie | FLUENT | 3 | June 29, 2009 01:51 |
| Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
| uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
