"Do a run with the residuals included in the results file."
Old   June 12, 2018, 05:11
Default "Do a run with the residuals included in the results file."
Stroopwafelandcoffee is on a distinguished road
I'm currently trying to run an incompressible problem (internal flow in a windtunnel) and my simulation seems to converge for a while and then it starts oscillating wildly. As a good forum user I went to look it up in the FAQ before asking my question here:
https://www.cfd-online.com/Wiki/Ansy...gence_criteria
I tried various things suggested in the guide, and I'm now fairly sure that it's probably due to poor mesh quality locally. And point 4 suggested that I'd do a run with the residuals in the .res file to locate the region where it all goes wrong. Being able to find the exact region where the divergence originates sounds like a golden feature to track down mesh errors.
Only I don't quite know how to set up a run like that. Would anyone be so kind as to put me in the right direction to create a .res file with all the proper info in it?
Stroopwafelandcoffee is offline   Reply With Quote
Old   June 12, 2018, 05:24
M
AtoHM is on a distinguished road
I dont have CFX at hand atm to look up the exact menu but I think it is under Output Control and there should be an option like output equation residuals or something like that.
AtoHM is offline   Reply With Quote
Old   June 12, 2018, 06:51
Thanks. I'll give that a go. Can I later check those in CFD post then? Or does it work differently?
Old   June 12, 2018, 08:33
M
Yes. You just open it in Post and then you can for example place a point and use maximum residual W-Mom or something like that in its definition. Its a bit tricky to find in the variable list but I think u'll manage.
Old   June 12, 2018, 11:44
I'm sure I will, thanks for all the help!
cfx, residuals, results
Time averaging results from a transient run Flow Squad CFX 4 October 24, 2011 09:11
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
intermediate results during a transient run Michael Skoblin CFX 1 September 25, 2006 14:00
Using results form previous run as inlet condition M CFX 2 January 16, 2006 22:43
transient run and residuals Mark Main CFD Forum 4 April 21, 2004 10:12
