Choking Mass Flow
Old   June 13, 2018, 14:47
Default Choking Mass Flow
Julian121 is on a distinguished road
Does choking occur in low pressure compressors?
I have experimental data for a compressor and I am using CFX to obtain performance curves.
In order to calculate choking mass flow, is it necessary to lower static pressure at outlet while inlet pressure should be kept constant?
I have done this but the mass flow keep increasing, while I lower the static pressure.
In experimental data choking mass flow is 2.5 kg/s.
In simulations, I have reached 3 kg/s and it keeps increasing!
The Mach number does not reach unity at the throat of compressor. At most it reaches 0.29 at the tip.
Can choking mass flow be predicted in low speed compressor?
If choking does not occur in low speed compressors, how was this mass flow calculated in experimental tests?
Julian121 is offline   Reply With Quote
Old   June 13, 2018, 21:15
If the simulation is set up correctly then, yes, CFX can predict choking mass flow on low pressure compressors (or just about any system for that matter, as long as the compressible Navier Stokes equations are a good model for the fluid).
Read the FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
And read the best practices guide int he CFX documentation on rotating machinery.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 14, 2018, 05:02
In experimental tests, mass flow was limited by a throttling valve which was not included in numerical simulations.
In numerical study, a bellmouth, IGV, Rotor, Stator and Outlet have been considered.
Is it not the reason why the choking mass flow cannot be predicted correctly since the throttling vale was not considered?
As I said, the calculated experimental mass flow is 2.5 kg/s, but in simulations as far as the static pressure is lowered in outlet, the mass flow keeps increasing!
The maximum pressure ratio the compressor can provide is 1.1.
Old   June 14, 2018, 19:49
Of course the throttling valve can affect the results.
Comparing the experiment with a throttling valve and the simulation without one appears to be meaningless. Your experiment and simulation need to look at the same thing - isn't that obvious?
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
rotor 37 choking mass flow rate fluent simulation sehs15 FLUENT 1 January 15, 2015 07:07
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 06:21
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
mass flow Wenbin Song FLUENT 0 September 27, 2005 14:00
