Expert parameter : part mmesh intersect option
Old   June 13, 2018, 18:19
Default Expert parameter : part mmesh intersect option
MissCFD is on a distinguished road
Here is the description of this expert parameter given by CFX guide.
This parameter can be used to enable a modified algorithm for partitioning
moving mesh cases. The modified algorithm recognizes moving domain
interfaces.
A value of 1 selects the newer algorithm. A value of 0 selects
the original algorithm.
The modified algorithm aims to keep both sides of a GGI interface within
the same partition, potentially improving convergence behavior in parallel
and reducing communication requirements between partitions.
This expert parameter affects parallel runs only; it has no effect on serial runs.
I don’t understand if this parameter is useful for all interfaces (stage, frozen rotor and transient rotor stator) when we have one rotating domain motion in our simulation or if they are talking about a mesh motion (mesh deformation) in a domain or maybe both?
Thank you very much for your help !
MissCFD is offline   Reply With Quote
Old   June 13, 2018, 21:31
The comment only applies to when the mesh is moving. I would suspect that is either mesh deformation simulations or transient rotor-stator simulations. Stage and frozen rotor simulations are not affected by that.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
