Surface 3 is not an exterior face of a 3-D Region. |
May 9, 2004, 22:28 |
Could you advice me how to create an internal wall to use for cfx5.6?? Internal wall will be used to transfer heat only.
AR |
May 10, 2004, 01:17 |
Surface is closed and also contains singularity
There is an error I find in BUILD (cfx 5.6)
"Surface is closed and also contains singularity" Any idea why I get this? |
May 11, 2004, 08:41 |
Re: Surface is closed and also contains singularit
You have created a cone-like surface in your geometry. You need to split the cone into two surfaces from the point to the base in order to mesh it.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] gmsh and boundary layers | kanuk | OpenFOAM Meshing & Mesh Conversion | 11 | August 14, 2015 12:35 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 18:48 |
Recover surface from surface mesh in IcemCFD | Jerry Tanner | CFX | 0 | August 20, 2008 12:48 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
