Stratification of methan
Old   April 29, 2004, 09:03
Default Stratification of methan
Jens
Hi
I have a case where methan is release in 33m height. It is only a case of dispersion of methan in the lower atmosphere. However the methan plume aproaches the ground level instead of being stratified inside the lower atmosphere. The uaing a ideal gas formulation of methan, O2 and N2 witha reference density of 1.23 kg/m3 (12 C temperature). I am using CFX5
Can anyone give me a hint of what I am missing in my modelling approach ?
Thanks in advance.
Regards
Jens
Old   May 11, 2004, 01:57
Default Re: Stratification of methan
Jeff
Buoyancy should be on, with a gravity vector set.
Make sure your diffusivity for the methane mass fraction is correct. The diffusion should balance the buoyancy and stratify. If the diffusivity is relatively low, the stratification layer will be compressed.
Jeff
Gas stratification Zoltan Turzo CFX 2 October 8, 2008 01:55
Multicomponent gas stratification Zoltan Turzo CFX 0 October 7, 2008 03:36
Unstable stratification khaiching Main CFD Forum 0 June 8, 2006 20:25
Setting Pr-t as a function of stratification? varghese FLUENT 0 October 14, 2004 10:27
Setting PRT as a function of stratification Olof Liungman Phoenics 3 January 29, 2002 11:49
