[Sponsors] | |||||
Sasan Ghomi
Rep Power: 16 ![]() |
Dear friends,
Is there any reference in which I can find the instructions for Y+ in CFX software program? I know that in Fluent User Guide everything is clarified but in CFX software program I cannot find a comprehensive reference for acceptable rage of Y+ in different turbulent models. Any help is appreciated deeply. Best Regards |
Rep Power: 146 ![]() ![]() ![]() ![]() |
y+ is a universal definition so guidelines for Fluent will apply to CFX as well, assuming you are using them on equivalent turbulence models and wall functions.
But in short: If you are using wall functions then you must get y+>11. The exact y+ you need will be problem dependent so you need to do a sensitivity analysis to find that. If you are integrating to the wall you need y+<1, but not too much smaller than 1.
Gert-Jan
Rep Power: 29 ![]() |
And if you use SST, you can live with a Yplus ranging from 0.1 up to 300.
Stuart
Rep Power: 27 ![]() |
Everyone who has questions about modelling boundary layers and y+ requirements should read these posts at LEAP Australia:
Tips & Tricks: Turbulence Part 1 - Introduction to Turbulence Modelling https://www.computationalfluiddynami...nce-modelling/ Tips & Tricks: Turbulence Part 2 - Wall Functions and Y+ requirements https://www.computationalfluiddynami...-requirements/ Turbulence Part 3 - Selection of wall functions and Y+ to best capture the Turbulent Boundary Layer https://www.computationalfluiddynami...oundary-layer/ Turbulence Part 4 - Reviewing how well you have resolved the Boundary Layer https://www.computationalfluiddynami...oundary-layer/ Tips & Tricks: Estimating the First Cell Height for correct Y+ https://www.computationalfluiddynami...t-cell-height/ |
Sasan Ghomi
Thank you so much for your comprehensive response.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
| How to visualize a range of yplus cells? | streamline90 | OpenFOAM Post-Processing | 3 | November 9, 2020 06:33 |
| AMI memory leak? | MichiB | OpenFOAM Programming & Development | 14 | August 1, 2015 19:18 |
| is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
| Yplus range for k-w model | Visser | Siemens | 5 | August 27, 2005 02:56 |
