Transient Rotor-Stator Interface
Like Tree1Likes
  • 1 Post By Opaque
Old   July 12, 2018, 10:41
Default Transient Rotor-Stator Interface
Julian121 is on a distinguished road
Does transient rotor-stator interface need equal pitch on both sides?
The reason why I am asking this is the CFX tutorial on axial turbine stage. In this tutorial, a transient interface was used between unequal pitches.
I am simulating a row of IGV, Rotor, Stator and a casing treatment.
The number of blades are 34, 38, 37 and 120 respectively.
I need to obtain performance maps and analyse the effect of the casing treatment on endwall flow.
I have mainly used steady state simulations but now I need to use transient simulations near to stall.
Should I use transient rotor-stator interface or transient blade row?
Julian121 is offline   Reply With Quote
Old   July 13, 2018, 15:30
Opaque will become famous soon enough
Unfortunately, there is no single answer for this type of problems.
If you really need to study the transient interaction, keep in mind that in ANSYS CFX a transient analysis with transient rotor-stator interfaces is equivalent to a "transient blade row" analysis with Profile Transformation; therefore, I recommend to set up the case as "transient blade row" and select Profile transformation. Then, you can easily upgrade your model with different pitch model changes, Time transformation, Fourier transformation, etc.
Profile transformation allows you to run with a single passage per blade row with an approximation at the row interfaces. You must be careful that the pitch ratio between rows is not too far from 1, so the approximation is reasonable. Because you have 37 blades in the third row, there is no possibility to reduce the model w/o an approximation of some kind.
Keep in mind such simulations are computationally demanding, so you must really know what you want to extract from the results and set it up properly ahead of time. You do not want to wait days, and realize the information you need is not being computed/stored or else when finished.
CTYH likes this.
Opaque is offline   Reply With Quote
Transient simulations: how to tell its converged (I've read the FAQ & user guides!) JuPa CFX 12 March 27, 2020 18:24
Large transient ".trn" files when doing time average dtmith CFX 2 June 28, 2015 10:06
Transient Statistics Results in CFD Post ashtonJ CFX 2 October 27, 2014 07:48
Transient or Transient Blade Row? liucheng8602 CFX 2 June 19, 2014 08:03
Best practice for transient simulations? siw CFX 5 October 30, 2010 06:45
