Does the study of vane-recessed casing treatment truly need transient simulations?
Old   July 14, 2018, 14:47
Default Does the study of vane-recessed casing treatment truly need transient simulations?
Julian121 is on a distinguished road
I am reading a paper on the necessity of doing transient simulation to study the effect of axial and vaned-recess casing treatments on a compressor.
The paper emphasizes that steady state simulations does simplify the problem.
"While some CTs, such as circumferential grooves, can be described by a rotation surface and can thus easily be included in conventional steady
simulations, the CFD analysis of other casing treatments like axial slot or recessed vanes, currently requires a time-resolving analysis of the interaction between such structures and rotating parts."
The reason is not clear for me although I have seen this in a few papers.
I have been doing steady state simulations to understand the physics of vane-recessed casing treatment.
The paper mentions that a mixing plane interface makes too large simplification and then concludes that a transient simulation is necessary.
I have used a frozen rotor interface in ANSYS CFX and not a mixing plane.
Does this apply to vane-recessed casing treatment in general?
Julian121 is offline   Reply With Quote
Old   July 15, 2018, 20:18
I have no idea what a vane recessed casing treatment is.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
ghorrocks is online now   Reply With Quote
Old   July 16, 2018, 08:55
Please see the attachment.
Old   July 16, 2018, 09:20
There certainly is going to be an interaction between the blade and the cavity. This means mixing plane approaches do not sound appropriate, but frozen rotor should be OK.
Also with all those sharp edged cavities in there I would expect to see large separations, and that can be problematic for RANS approaches. I suspect accurate results will require a SAS or DES approach. But a RANS model should give you the general idea (as long as you don't mind a reasonable margin for error).
The simulation of a centrifugal compressor with holed casing treatment gongmq CFX 4 July 16, 2018 06:15
Fitting casing treatment on rotor Julian121 CFX 1 May 11, 2018 08:21
Interfaces between blade channel and casing treatment SNeCu CFX 3 September 20, 2017 23:36
Add casing treatment in NUMECA SNeCu Fidelity CFD 9 July 25, 2017 00:15
transient term treatment Mike Main CFD Forum 9 February 18, 2003 14:26
