how to see the mesh in PRE/POST?
Old   June 10, 2004, 13:56
Default how to see the mesh in PRE/POST?
ioana
Hi everybody!
I want to know if there is a way to see the mesh in POST or PRE. It's very urgent!
Have a nice day, Ioana
Old   June 10, 2004, 20:28
Default Re: how to see the mesh in PRE/POST?
Francisco A Duque
Hi Ioana,
Just load the gtm file in post, and then edit the wireframe object setting Edge angle to 0 degrees. that should display your surface mesh in the 3D viewer.
I hope that is the answer you were looking for.
Regards
Paco
Old   June 11, 2004, 02:10
matej
Or if you want to see the mesh (to see the density at particular places or whatever) you define a plain and on render tab for this plane click the "draw lines" on.
in cfx5.7 is the surface mesh displayed from the moment you define the domain. At least it does for me )).I think.
matej
Old   June 11, 2004, 04:27
Default thank you
ioana
Hi Paco & Matej!
Thanks a lot for your advice. It works!
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
Mesh Mignard FLUENT 2 March 22, 2000 05:12
