Multiphase Problem (Urgent)
Old   June 10, 2004, 08:10
Default Multiphase Problem (Urgent)
Dadang
Dear all,
I have a problem with multiphase fluid, i want to analize 2 fluid on ship.i use thin surface between 2 fluid, but i can't mesh the model and i can't run definition file.i need all information about that problem,
thanks all
Old   June 10, 2004, 12:06
Default Re: Multiphase Problem (Urgent)
Anne
Hi dadang,
What is the physical desciption of the location of the two fluids? Thin surface, i assume, is a wall. Do you mean a wal between two fluid, not a free surface? From the little information you have provided, one is likely to think of a homogeneous multiphase flow.
However, when you talk of a ship, i am tempted to think of a flow around a blunt body (Tut5 CFX5.6). If this is the case then from your post is hard for me to understand why the thin surface! Are you simulating air in the ship and the water surrounding it?
regards anne
Old   June 10, 2004, 23:41
adio
hi Anee, may be i'll discprite about dadangs problem dadang, the thin surface is a wall which separate two fluids in operational ship there are two fluids(water and air) flow around hull so he is simulating air and water surrounding the ship. thanks
Old   June 17, 2004, 05:17
dadang
thank for your attention yes, i want to simulate ship at real condition at sea,i want to calculate the resistance air and water surounding the ship.i need more information about that thanks again ragards dadang
Old   June 21, 2004, 08:46
Anne
Dadang,
Now i understand it this way; the lower part of the ship is covered by fluid A (water) the upper part of the ship is covered by fluid B (air). There is an interface between the two, where air and water meet. I have been thinking about that problem but I must confess that I do not, as yet, have a suggestion worth posting. The problem seems tricky because you must have two separate fluids and;
(1)No (negligible) interpenetration between A and B, therefore, no Euler-Euler scheme (2)Different flow fields, therefore, no multicomponent model ( I think, i may be corrected).
Please try help desk, you might have done this already! Best of luck.
regards anne
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 21:30
UDF problem in multiphase model Amir Khodabandeh FLUENT 1 March 13, 2009 09:43
Urgent Problem with Hypermesh and CFX Luk CFX 5 March 14, 2008 05:59
another problem about saving a case: Urgent J.Z Phoenics 0 January 15, 2007 16:02
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 17:38
