How to define Energy source in solid region ?
1 Attachment(s)
In my projects, spheres (solid) are fuel element and I want to define energy source in solid region. But in CFX, unlike Fluent, there is no option to do that. in Fluent, we can specify ONE energy source in solid region but in CFX, I have to use source point in CFX? Thanks in advance. |
Yes, you can define a source in a volume region in CFX. Define the volume region as a subdomain and you will be able to define sources on it.
Thanks a lot. As mentioned before my geometry consists of solid (spheres)and fluid (the space between spheres)domains, and I named the whole geometry, "Core". Now in "Default domain" in "location" I have 3 locations; Core, Primitive 3D (solid), Primitive 3D A (fluid). I was wondering If I am able to change the names? I want to change primitive... to fuel , etc. Also, when I want to define fluid and particles,.. For fluid, I should choose its location (Primitive 3D A) and for solid (Primitive 3D )? I mean can I choose location, Core and then just change "domain type" and define materials for fluid and solid? Many thanks |
I would recommend against changing the names of the mesh regions. If you change the mesh it means it cannot update the links easily. If you change the names in the meshing software then the names will flow through to CFX - that is a better way of doing it. Alternately, when you define the domains you can call the domains whatever you like.
As for defining the regions to be fluid and solid - this is shown in the CFX tutorials. There are a few which cover CHT (conjugate heat transfer) modelling, so look to see how they set it up. |
i agree with Glenn, i think it is better to give name selection in the meshing itself. Setting heat source: 1. split domain in to two parts (solid and fluid domain) 2. right click solid domain and select subdomain 3. in sub domain you can give total heat source. Note: You should have solid-fluid interface for your problem Thanks... |
you say split domain to 2 parts i.e. I should define 2 domains? solid domain and fluid domain. I already did that in sub domain I can define heat source but i have a problem with its unit! I mean my unit is (w/m3) but in CFX (W). In fluent I didn't have such problem because in it the unit was (w/m3). I should write an expression for it? Also How can I sure that I have a solid-fluid interface for my problem? I mean I should define it in meshing stage? Many thanks in advance |
Have a look in the CFX documentation on sources. There are a few different ways of specifying them.
For the solid-fluid interface - if you are unsure you have this correct then do some tutorial examples to see how they are set up. And if you have not set them up correctly then the temperature of your fuel spheres will quickly increase to huge temperatures as nothing is cooling it down - so it will be easy to spot if you have it wrong. |
Dear ghorrocks,
Thanks, I already read CFD tutorial but I didn't find anything related to my problem (heat source). As you know Software tutorials don't cover any thing and so I have to ask my questions here and other sites. The best way to me is to use other's experience. Thanks |
please follow the steps below, 1. In space claim you should select share options under properties 2. If you select share option then cfx will create fluid solid interface automatically when you split domain (fluid and solid domain) in cfx 3. For the interface boundary condition 3 types available. Generally people will select conservative heat flux across interface. 4. as you know in fluent you can give heat source as a volume heat generation rate (W/m^3). but in CFX it is only heat flow (W). so it is better to convert volume heat generation rate (W/m^3) to total heat source (W) (simple conversion) Thanks... |
1 Attachment(s)
But where? in CFX or meshing stage? since in CFX I don't find "share option" and properties. By the way, I asked it in other sites too and I was told that in Meshing stage, I should have one geometry with 2 parts (fluid and solid zones) then CFX itself will create solid-fluid interface but now I have 2 geometries. |
sorry i did a mistake. Follow the steps below, 1.Left click your geometry/part file and select share option under analysis/share topology. 2. Refer the following link in YouTube (share topology) https://www.youtube.com/watch?v=h43E1YO1LiM&t=65s 3. Did you enable automatic default interface in cfx. If not check the following link. https://www.sharcnet.ca/Software/Ans...DialogPre.html Thanks... |
Thank you for providing me with links. I already defined interfaces in my mesh file and then in CFX , in interface section, I created 2 interfaces.. but now my problem is for inner spheres (4 spheres as you see in the pic) how can I define 2 interface sides? since as you know for each interface one side should be for solid and other side should be for fluid.
Thanks |
"Did you enable automatic default interface in cfx. If not check the following link"
Sorry but when I right-click the Simulation object in the tree view there is no "Automatic Default Interfaces". by the way , I see "interfaces" object below the "simulation" object. |
the video is for Ansys mechanical and I created my geometry in CFX, so It didn't help me. By the way thanks.
