July 29, 2004, 16:43 |
HEXA-Mesh
Hi guys
I was wondering if there is a way I can control the movement of the mouse cursor on the HEXA environment screen. Like, Snap or Grid in AutoCAD where you can turn those command off and that one can click any place on the screen. This is because I am trying to move a vertex to a point vertex but it doesn't fit the correct position I want. I always have to zoom in until I get the right spot. Also can somebody tells me if is possible for me to split edge to curves or block to curves? Any suggetion is highly welcome. Thanx a lot! |
July 30, 2004, 00:14 |
Re: HEXA-Mesh
Hi KKA! Why you not use Projection,Vertex->Point? Then your vertex will be associated to point and will move to that point, alternatively you can use Edges,Set location. But I think that first choice will be better. For second I simply can not understand why you need that. Simply split your edes or blocks and move vertexes to correct positions... Regard, deLuther.
July 31, 2004, 15:00 |
Re: HEXA-Mesh
Thanx a lot! I'll give it a shot!
Regards! |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] export hexa mesh to fluent | Wieland | ANSYS Meshing & Geometry | 37 | January 23, 2013 03:27 |
[ICEM] Hexa Mesh Smoothing | Jules | ANSYS Meshing & Geometry | 6 | December 4, 2010 18:00 |
