A beginner's problem
Old   August 9, 2004, 05:45
Default A beginner's problem
lingo
Hi,friends:
I began to use cfx5.6 several days ago.I practise According to the tutorial.However,when I set some parameters in panel ,I cann't find the last buttons such as "apply"or "finish",so I had to quit. For example,when I set-mesh parameter-angular revolution or creat-infalted boundary,I cann't see the "apply".I try to solve it with amplifying or adjust the resolution ratio,but don't work.
Could you give me any suggestion?Excuse me for my poor expression.
Regards lingo
Old   August 9, 2004, 06:20
Default Re: A beginner's problem
Meri
Lingo, What OS are you using ? In Linux, sometimes you have to adjust the screen and font sizes and I think it is the same under windows. Don't get discouraged, read the introductory manual, there is a way to resize everything so it fits your screen
Old   August 9, 2004, 10:42
Yuan
Lingo,
I met the same problem as you before. All the unseen buttoms (the lower part of the panel) are covered by the main interface of CFX. You can just enlarge the main to full screen so that enough area can be set aside for your current using panel. Good luck.
Old   August 10, 2004, 02:01
lingo
Meri,Yuan:
You are right.I solve it.Thank you very much! lingo
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Beginners problem Zurayk CFX 4 January 11, 2007 09:56
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
