Heat transfer problem
Old   September 13, 2004, 01:19
Default Heat transfer problem
Brian
Hello!
I used CFX 4.4 to solve my problem¡AIf I consider a heat transfer problem of a solid¡Aone of the surfaces has a heat flux(if I give a constant value)¡Cbut¡Aeven if I give any heat flux value(compare with heat flux maximum=20000 and minimum=200)¡Atime step is 10sec ¡A I saw the temperature was not be transfered¡Aand different temperature scales in same region(the minimum temperature was the same)¡C
In fact¡Aif we supply a large heat flux value¡Adue to have a large energy ¡Athe temperature should be transfered to all solid immediately¡Awhy I had different temperature in the same region¡Aand sence the temperature was transfered so slow¡Acan anybody do me a favor to solve this problem?? thanks in advance!!
Heat transfer problem at nucleate boiling MrStuebb FLUENT 12 March 14, 2017 13:31
Wall heat transfer coefficient (HTC) problem Mohamed khamis CFX 1 January 15, 2010 23:12
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Heat Transfer Problem Help JB FLUENT 2 October 18, 2006 18:54
heat transfer problem. vipin CFX 2 July 18, 2006 10:05
