Not enough free memory is currently available |
September 16, 2004, 05:03 |
ERROR #001100279 has occurred in subroutine ErrAction. Message:
*** Run-time memory configuration error *** Not enough free memory is currently available on the system. Could not allocate requested memory - exiting! Is it caused by insufficient RAM, or something else? Any advice is appreciated! |
September 16, 2004, 05:43 |
Re: Not enough free memory is currently available
HI Windows workstations with large amounts of memory (>2GB) can fail during some stage even if the total amount of requested memory is less than 2GB. If this happens, first verify that sufficient Virtual Memory has been allocated in the Operating System. It is recommended that the maximum size of Virtual Memory be at least twice the size of the available physical memory.
And if till there is error then in solver manager there is a option in advanced controls in that go to solver and there is memory allocation factor Default value is 1.0 change it to 1.1 or 1.2 it may be it will help you |
September 16, 2004, 06:15 |
I such case you need decrease this value 0.9 or less. (Of course if memmory requirements is not much more than available memory (2Gb on 32bit)). If such memory amount not sufficient try to play with individual allocation factors by variable types (integer,real,...). This type of error displays that you need 64bit machine or parallel (in simple words - more memory in system, not CFX).
September 16, 2004, 06:30 |
Trushar Gohil, Your advice works! Thank you!
September 16, 2004, 06:36 |
more, I tried local parallel!
September 17, 2004, 04:02 |
just for record, using local parallel when you have not enough memory on the box, is waste of time and power. Local parallel will demand bit more memory on single mashine than the single process itself, you need to distribute not only the worlk load on CPU but the memory too, so distributed parallel is the right thing to try.
matej |
September 17, 2004, 06:33 |
But local paraller can be useful to run on single PC problem that requires more than 2Gb of memory. I did run job, that required about 3Gb, as local parallel (MPICH under windows) on single CPU (No HYPErthreading). When I test performance in such case (on task <2Gb), local parallel (2 processes on single cpu) was slightly (very little) faster than same task in serial. (just my experience). Of course distributed parallel was faster.
Memory error? | Young | CFX | 3 | September 30, 2008 12:33 |
CFX CPU time & real time | Nick Strantzias | CFX | 8 | July 23, 2006 18:50 |
ERROR-- PDA free: Attempt to free memory...... | tuks | CFX | 0 | May 5, 2005 09:34 |
How to free memory after running Fluent ? | David | FLUENT | 1 | February 27, 2004 04:59 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 07:27 |
