September 21, 2018, 11:08 |
CFX-Solver Error
Jackyy
Rep Power: 7 |
3 isolated fluid regions were found in domain Default Domain
solver is giving like that error. which one is program about that erroor |
September 21, 2018, 20:09 |
Rep Power: 143 |
Search the forum on this question, it has been asked several times.
You need to make sure your mesh is joined together. You cannot have isolated regions. So non-contiguous mesh regions need to be joined with GGI interfaces.
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
