October 14, 2018, 06:22 |
Laminar flow around cylinder
Sasan Ghomi
Rep Power: 14 |
Dear friends,
I am modeling the fluid flow around a cylinder with Reynolds number of 4.9E3. According to theoretical books (experimental results), the flow is supposed to be laminar. So, I chose laminar as a turbulence model. First question: Is it a right job to choose laminar model even though the flow encompasses vortexes? Also, I am about to calculate heat transfer convection around the cylinder and I have serious convergence problems especially when it comes to the the imbalance of energy equation. By the way, the grid is refined perfectly and the range of Y+ in below 2. Any idea for better convergence? Any hints? I do appreciate your attention. Best Regards |
October 14, 2018, 06:27 |
subhankar das
Rep Power: 7 |
From what point of view you can say that the flow is laminar?
October 14, 2018, 11:09 |
Sasan Ghomi
Rep Power: 14 |
I need to make a comparison between numerical results and the empirical correlations.
Which types of simulation can generate better results for this Reynolds number? Laminar or Turbulent? |
October 14, 2018, 17:55 |
Rep Power: 143 |
I answered this same question in your other thread: Convective Heat Transfer Coefficient (Flow over cylinder)
Please continue discussion on this topic on the other thread.
Flow over 2D Cylinder, Laminar and Turbulent | Tsr63 | FLUENT | 5 | November 13, 2014 12:13 |
flow over a cylinder, turbulent and laminar | Chetan Kadakia | FLUENT | 27 | December 8, 2012 05:08 |
DPM transient laminar flow over a cylinder | JSoares | FLUENT | 1 | April 12, 2011 02:37 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 01:12 |
2D cylinder, external, laminar and turbulent flow | Dave | FLUENT | 0 | December 6, 2006 20:42 |
