Outputing Vorticity into .res file
Old   November 30, 2004, 06:36
Default Outputing Vorticity into .res file
CFX User
Hi Guys, Please could someone tell me how to turn on the output of vorticity into the CFX5 results file.
I have read that you need to put this into the CCL:
LIBRARY:
VARIABLE: vorticity
Output to Postprocessor = Yes
END
END
but can't work out how to do this.
CFX User
Old   November 30, 2004, 16:33
Default Re: Outputing Vorticity into .res file
I assume you know how to edit the CCL for a run. If it doesn't work for you by editting the CCL, edit the VARIABLES file in the <CFXROOT>/etc directory. Make sure you keep a copy of the original file as if you stuff the VARIABLES file CFX will not run correctly!
Old   December 1, 2004, 00:54
Pete
Hi Glenn,
Is there any default variable defined as "vorticity" in CFX Post 5.7? I can't find it while trying to plot the contour of vorticity. Should we define it ourselves? Thanks for help.
Old   December 1, 2004, 06:25
CFX User
Glenn
I have edited the VARIABLES file in the /etc directory and it seems to work. Could you tell me how to edit the CCL for just the run itself. I have tried reading the variable command as per my initial post via the CCL import but just get error messages. I'm not sure what i'm doing wrong. I know how to put expressions into CCL but not extra commands. Is the editing of the CCL for extra variable done in pre or solve!
Many Thanks
CFX User
Old   December 1, 2004, 15:57
You should be able to put the CCL in using Pre or the solver, but I don't know the exact syntax. Hopefully somebody on the forum will know, otherwise contact your support rep.
Old   December 1, 2004, 15:58
Hi Pete,
If you did not edit the VARIABLES file or add the CCL to include it then the only way is to calculate it yourself in CFX-Post.
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
